Activity › Forums › AJA Video Systems › Analog capture with Kona 2?
Posted by Bernardo Gortaire on May 28, 2005 at 5:51 pmIs it possible?
How can a Kona 2 work with a UVW 1800 Betacam SP?Walter Biscardi replied 21 years, 3 months ago 3 Members · 2 Replies -
Jeremy Garchow
May 28, 2005 at 9:51 pmEither get yourself an io la:
https://www.aja.com/products_Io.html#iola
or get a component betacam to SDI video converter:
And for audio you can get either a flying cow a/d/d/a audio converter:
https://www.m-audio.com/products/en_us/FlyingCow-main.html
or perhaps you can check out the newer aja embedder/disembedder (although I don’t have experience with this particular product):
https://www.aja.com/hd10ama.htm
You can then use the Kona2’s analog video output & the flying cow/aja audio devices for audio.
Hope this helps.
G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Walter Biscardi
May 29, 2005 at 1:39 amUmm, you posted this exact same question down below in a thread called “Panic”. No need to post the exact same question a second time when there are plenty of answers down below.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
