Activity › Forums › AJA Video Systems › Analog Audio on Kbox
Posted by Steven Escobar on September 6, 2005 at 8:21 pmI’m having problems getting analog audio from the Kbox RCA output to my audio board. I’ve double checked my settings on my Mac and FCP and both are outputting to the Kbox. Is there something I’m doing wrong?
Any suggestions are appreciated
Steve
Fred Connors jr. replied 20 years, 12 months ago 4 Members · 6 Replies -
David Battistella
September 6, 2005 at 8:46 pmthe only analog outs are the two RCA’s on the K-box.
David
David Battistella
September 6, 2005 at 8:47 pmSorry,
I just re-read your post.
Are you getting video out of the K-BOX. Maybe the connection to the computer isn’t happening.
david
Fred Connors jr.
September 6, 2005 at 8:50 pmWhat are your settings in the System Preferences -> Sound? Device and Level?
Are you getting audio out of the AES and or SDI?
Fred
Steven Escobar
September 6, 2005 at 10:36 pmI am getting video output from the analog out of the Kbox and my settings in system preferences are both set to Kbox on Input and Output and level is set to high.
Walter Biscardi
September 7, 2005 at 2:42 amAre you getting audio from the digital outputs?
Have you done the “Refresh A/V Devices” within FCP?
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
Fred Connors jr.
September 7, 2005 at 1:12 pmYour System Preference -> Sounds SoundOut should be set to KONA2 and the output level set to 66% or 67%. Input level is reset by FCP settings.
The KONA Cntrl Panel sets the input choice AES or SDI, but all outputs should be live at all times.
Are all both of the cables connected properly from the KONA to the Kbox?
You should get audio out at all times including system alerts. If not you may have an issue with the kBox.
And since you’ve not answered the simplest question, I’ll ask again,
Are you getting any digital audio out of the KONA2 directly?
Are you getting any digital audio out of the Kbox?
Fred
