Activity › Forums › AJA Video Systems › Analog audio levels
  • Analog audio levels
    Posted by Kerry Soloway on September 9, 2010 at 4:47 pm
    One of my clients, still working only in SD, is using the Io with FCP 5. Given their “prosumer” audio monitoring, I want to have the Io output at +18 dBu as opposed to +24.
    Even though I set this using the ProIo Control Panel, and saved it as a new setup, it seems to keep defaulting back to +24.
    What, if anything, am I doing wrong? Also, I seem to recall that there is an issue as to when one uses the control panel. Is it before opening FCP or after?
    Kerry Soloway
    http://www.NightingaleEditorial.com
    Kerry Soloway replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
