Activity Forums AJA Video Systems Analog Audio in Control Panel
  • Analog Audio in Control Panel
    Posted by David Massachi on July 22, 2005 at 3:48 pm
    In the “Control” tab of the AJA Control Panel, there is a box called “Analog Audio Level”. There are 2 choices: “+18 dBu FSD” or “+24 dBu FSD.”
    1. What do these settings mean?
    2. What is “dBu FSD?”
    3. What should I have it set to, in which circumstances?
    My system:
    Dual G4 1.42 GHz
    2 GB RAM
    OS 10.3.9
    FCP 4.5
    QT Pro 6.5.2
    Compressor 1.2.1
    AJA Io with Driver v2.0 and Firmware Update v23-28
    AJA ProIO Control Panel v 1.0.0
    Uncompressed 8-bit 4:2:2 via SDI to/from DVW-A500
    massachi
    Vladislav replied 21 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Lee Berger
    July 24, 2005 at 11:39 pm
    FSD refers to Full Scale Digital. According to Wikipedia it is “The maximum amplitude a digital system can represent.” They go on to say “Once a signal has reached full scale all headroom has been utilized, and any further increase in gain results in an error known as clipping.” I would imagine that most decks and small mixers would conform to the 18dbu FSD specification. If you hear distortions on peaks then you can try the 24dbu FSD setting.
  • David Massachi
    July 25, 2005 at 3:18 pm
    On Wikipedia they talk about FSD in regards to digital audio. But the place on the Io Control Panel that I see this setting is in the area called “Analog Audio Level”. Does that mean that you can set the analog output level to be the equivalent of a digital audio setting with 18 dBu of head room or 24 dBu of head room? Does that make sense?
    What is the difference between dBu and dB?
    massachi
  • Lee Berger
    July 25, 2005 at 3:55 pm
    It makes sense to me because although you’re bringing the audio in via analog, it has to eventually go through the Io
  • David Massachi
    July 25, 2005 at 4:28 pm
    Thanks a lot, Lee. Very helpful post.
    massachi
  • Lee Berger
    July 25, 2005 at 5:33 pm
    Your are welcome massachi. I also learned something myself as I did not know what FSD and dbu referred to until I looked it up.
  • Vladislav
    August 18, 2005 at 5:50 pm
    where do you find this control panel?
    thanks
  • Lee Berger
    August 18, 2005 at 6:54 pm
    https://www.aja.com/support_Io.html
    look for
    Io Control Panel V1.0.0 with related Firmware
  • Vladislav
    August 18, 2005 at 8:38 pm
    Ok thank you for your help
