Activity Forums Adobe After Effects anaglyph question
  • anaglyph question
    Posted by Nicky Rodriguez on November 2, 2007 at 3:06 pm
    I’m doing an anaglyph project the video was shooted with 1 camera, then i load the footage in ae, and make a composition with the footage and 1 camera with cyan solid in darken mode, move the camera 10 pixels to the right and named the compo 3d right, then i duplicate the compo, and replace the cyan solid with red solid, move the camera 10 pixels to the right and called this compo 3d left, then i put both compos in a new compo, and put the cyan on top in lighten modei got my anaglyph effect, but only see the whole compo move back in 3d space, how can i make the whole compo move front in 3d space, to get the effect of coming out of screen?, any help will be appreciated it, thanks
    Nicky Rodriguez replied 18 years, 10 months ago 3 Members · 10 Replies
  • 10 Replies
  • Nicky Rodriguez
    November 2, 2007 at 4:03 pm
    i tried that too, but can i do that with only 1 camera shooted?, if yes, how can i do that?, cause both cameras are same
  • Nicky Rodriguez
    November 2, 2007 at 4:34 pm
    Ok, i have two cameras shooted now, but still no luck, how’s the right way to setup 3d glass effect?, i have the red and blue glasses
  • Nicky Rodriguez
    November 2, 2007 at 5:37 pm
    I tried, and did everything as manual says, but i think maybe i need to do something else, because still no works
  • Steve Roberts
    November 2, 2007 at 6:17 pm
    Sorry … but on set, on location, did you shoot video with one camera or two cameras?
  • Nicky Rodriguez
    November 2, 2007 at 6:24 pm
    First i tried with one camera, and didn’t work, then i tried with 2 cameras, so now i have 2 tapes with same footage, both cameras in same tripod mounted on one plate
  • Jon Agnew
    November 2, 2007 at 7:36 pm
    wait a tick. after effects can do this???
    how good are the results?
  • Nicky Rodriguez
    November 2, 2007 at 7:46 pm
    Dave
    Thanks for your answers, when i said cameras were mounted on the same tripod plate, i mean side by side looking same point of interest, looking for the perspective you explain, and i put footage from cameras in 3d glass effect, but i get too much ghosts, i played with controls, but no look, cause when i get both images aligned at centre, objects near to borders looks with ghosts, and image in centre doesn’t look too forward to the screen as i desire
  • Jon Agnew
    November 2, 2007 at 7:52 pm
    i’m so curious to see this effect in action. why, oh why didn’t i keep the glasses from Superman Returns?
  • Nicky Rodriguez
    November 2, 2007 at 7:55 pm
    Red and Blue (the regular cartoon glasses), the weird is that i can see the effect on every movie i found on the net, but not mine, using the same glasses
  • Nicky Rodriguez
    November 5, 2007 at 3:16 pm
    Ok, i was working on the footage of the 2 cameras and i found the 3d depth in one of the objects in the scene, i have a chair and a girl behind the chair, there i looks the chair in front, nice effect, but i notice the other objects in the frame are not aligned when i make the effect, too much ghots, so i think is a matter of distance from the cameras to the scene, does anybody knows how far should be the cameras from the scene?, my scene is a girl sitting in a chair in a room, behind her are some furnitures and lamps, thanks
