Activity › Forums › VEGAS Pro › an unattended series of renders
  • an unattended series of renders
    Posted by Robert Stuart on November 21, 2006 at 8:48 pm
    I have a list of projects that I would like to render. Additionally, I will be using Xvid so each project will have to be rendered twice. It would be nice to have all these tasks programmed so that I will have to pay attention.
    Is there a way to program a series of renders without requiring user input?
    Even if there isn’t a way to render more than one project, but only rendering just one project for the two passes without user interaction between, is helpful.
    Robert Stuart replied 19 years, 10 months ago 3 Members · 4 Replies
  • Edward Troxel
    November 21, 2006 at 10:19 pm
    Look at the Veggie Toolkit for a very flexible batch renderer. However, Vegas DOES come with a built-in batch renderer – tools / scripting / Batch Render.
    I believe you’ll need the extra capabilities of the veggie toolkit, though.
    Edward Troxel
    JETDV Scripts
  • Robert Stuart
    November 22, 2006 at 11:50 am
    Thank you. That bundled script may not have the feature of rendering multiple projects, but at least I can have one project render both passes. This is important when rendering takes around 8 hours (for a 3 minute video :)).
  • Tevya Washburn
    November 22, 2006 at 5:55 pm
    The bundled script will also allow you to render regions. With the ability to import other projects as clips, you could create a new project, then place each of the projects you want to render on the timeline. Make each of the projects on that timeline a region, then use the batch render with the region option set. This will render out each region (in this case each project) for you as a separate file.
    –the Fiddler
  • Robert Stuart
    November 23, 2006 at 7:35 pm
    I will try this. Thank you.
