Activity Forums Adobe After Effects “An output module failed” error
  • “An output module failed” error
    Posted by Ayako Minatodani on February 20, 2011 at 8:13 pm
    I just installed CS2 AE and have been getting this error message on every attempt of rendering. After Effects error: Rendering error while writing to file”/users/….” An output module failed. The file may be damaged or corrupted/ (-1610153464)
    I could render it as TIFF sequence but not in .mov or .mpeg. I could also render the same file in CS4 no problem.
    Any solution?
    aya
    Ayako Minatodani replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
