Activity › Forums › Adobe After Effects Expressions › an expression to animate x position of a text layer
  • an expression to animate x position of a text layer
    Posted by Ahmad Hesam on August 22, 2020 at 12:14 pm
    hi;
    I am making a bar graph ina after effect, I used a trim path for animation and used “linear” expression to relate original data to trim path 0-100.
    as I created a text layer for its source amount, I’m still in a need of expression to relate my text layer X value to follow along the trim path.
    any idea how?
    thanks.
    Ahmad Hesam replied 6 years ago 4 Members · 8 Replies
  • 8 Replies
  • Geert Schaap
    August 24, 2020 at 9:06 am
    You could use after effects/window/ “Create Nulls From Paths” to trace the selected path.
    This will give you a null object that travels from the start of the path to the end in percentages.
    Parent the text layer to the null object, and link the percentage of that null to the percentage of your trim path.
    There’s a default expression on the null of the traced path that will automatically loop, you can disable that by deleting the expression as a whole. (it won’t effect nothing other then the loop itself).
    Hope this helps!
    Good luck!
  • Filip Vandueren
    August 24, 2020 at 9:08 am
    This would work:
    l = thisComp.layer("Bar Chart 1");
    p = thisComp.layer("Bar Chart 1").content("Shape 1").content("Bar 1").path;
    tr = thisComp.layer("Bar Chart 1").content("Shape 1").content("Trim Paths 1").end;
    extra_margin = [0,-30]; // an extra 30 pixel margin
    pos = l.toComp(p.pointOnPath(tr/100) + extra_margin);
    if (hasParent) pos = parent.fromComp(pos); // take care of parenting
    pos
  • Andrei Popa
    August 24, 2020 at 2:58 pm
    Hey Filip, that’s a very nice expression.
    Just curious, do you think that could be made to work with multiple shapes and only a trim paths that completes them individually?
    Andrei
    My Envato portfolio.
  • Filip Vandueren
    August 24, 2020 at 7:25 pm
    You mean as a bar graph ?
    If I understand correctly, i this scenario you would have bars that have actually different lengths, revealed by just one trim path on the whole group ?
    In theory yes… Though when the paths are curved, it’s harder to be precise: you first have to run a loop to “measure” the length of each path in pixels.
  • Andrei Popa
    August 25, 2020 at 3:31 pm
    I hoped for an easier solution for some curved paths.
    Andrei
  • Ahmad Hesam
    August 29, 2020 at 9:25 pm
    that worked like a charm and I appreciate it.though, can you give me the definition of this line of code. sorry I’m a noob at coding.
  • Filip Vandueren
    August 29, 2020 at 9:50 pm
    Sure, it does use a few different of methods:
    p was a reference to the shape of the line you drew (path)
    tr was a reference to how far the End-parameter of the trim Paths Effect was set.
    p.pointOnPath() = is a method that returns the pixel coordinates of a point along a given path (p).
    At 0 it’ll give the position of the vertex, at 1.0 the position of the last vertex (or the first again, if the path is closed), and in between it’ll give points along the path.
    It is very close to what “Trim Paths” does visually, but gives us coordinates.
    Trim Path however goes from 0-100, so we divide by 100 to get values between 0 an 1.0
    p.pointOnPath(tr/100) + extra_margin -> this would give us the pixel coordinates of where the line stops + some extra pixels higher (extra margin).
    However: these coordinates are relative to the layer the path is on, we cannot just use this coordinate for another layer ‘s position and suppose they are the same: the layer where the coordinates comes from could be sacled, rotated, parented,… for every layer an ‘internal’ coordinate like [100,100] can mean a totally different pixel on screen.
    layer.toComp([x,y]) fixes this: it is a “layer space transform method” that gives us the actual position in the comp of a position ‘inside’ of a layer.
    There might be other factors of why that position would still note work as the precise position for another layer (if it’s parented form example), but that is fixed in the next line with a fromComp(), which does the inverse of toComp()
  • Ahmad Hesam
    August 31, 2020 at 4:42 pm
    “PointOnPath” and “ToComp”.
    thanks, I’m in your debt.
