Activity › Forums › Adobe After Effects › an expression for a loop-able wiggle
  • an expression for a loop-able wiggle
    Posted by Filip Vandueren on June 10, 2005 at 9:10 am
    Hi all,
    not sure if something like this has been posted before, but I think I rememebr seeing the question sometimes.
    if you find you need to wiggle something, but you want it to loop seamlessly, you can use this function:
    function loopedRandom (t, loopTime, seed) {
        seedRandom(seed, timeless = true);
        startPos=random([5000,5000])
        radius=0.25;
        x=startPos[0] + Math.cos(degreesToRadians(360*t/loopTime))*radius
        y=startPos[1] + Math.sin(degreesToRadians(360*t/loopTime))*radius
        return noise([x,y])
    This function returns a value between 0 and 1, based on t and it will return the same value every loopTime seconds.
    Unfortunately, it doesn’t have frequency and octaves like wiggle, but by increasing the radius-value you get faster changing results.
    It works by sampling the values in a noise-field on a circular path. (see Dan Ebberts’ tut. on After Effects Hidden Gem: noise() for more info on noise)
    for example use it like this:
    position + [ loopedRandom(time,10,1) , loopedRandom(time,10,2) ]*50 // 2-dimensional -> call twice with diff. seed
    Mylenium replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mylenium
    June 10, 2005 at 9:30 am
    Kinda cool ;o).
    Mylenium
    [Pour Myl
