An experiment for a CS5 / 5.5 user?
I’ve already used up my “try before buy” CS5 installation so has anyone got CS5 / 5.5 and a few minutes spare?
Could you try:
1. Make a 1920×1080 psd file (with some smallish text).
2. Make a low res 16×9 prem pro sequence (eg 160×90)
3. Put the psd file onto that timeline and scale it down to full-frame.
4. Export the timeline using Adobe Media Encoder as a 1920×1080 h.264.
How does it look?I was hoping that this workflow would “do the math” and produce a nice crisp export of the 1920×1080 psd file, instead of looking like it’s scaled it down to 160×90 then scaled it up again. In CS4, the Export preview window *looked* like it was going to do what I need, but the MOV I ended up with was all blurred and jaggly. 🙁
I get batches of movies in a variety of formats/frame rates/sizes/volumes/field-settings/letterboxing etc, to which I have to add a fade-to-black slide at each end. I’d hoped to make a native-size sequence for each movie, then add a before and after sequence onto each, then export at native size, compressed, DV and 1080 TIF sequence, with as little image degrading as possible, and making it easy to update a slide and re-export the whole lot if needed.
The other option is to blow up the smaller films to match the 1920×1080 slides, then export to smaller sizes, but I think this will degrade the film quality by expanding them and shrinking them again.
So I think my QuickTime Pro workflow (where I have to make lots of slide movies of different sizes) still seems the best option.
Any suggestions gratefully received.
– Paddy
