Activity Forums VEGAS Pro An error occurred while loading the project file – The Item was not found
  • An error occurred while loading the project file – The Item was not found
    Posted by Salva Sánchez on April 28, 2020 at 11:34 am
    Hello, I need your help. When I try to open a project I finished it says “An error occured while loading the project file. The item was not found”. It does it too on the .bak file and there is nothing in the appdata folder. I have tried everything, but I know the project is not gone as I see the size when I click on properties. I started to render yesterday, cancelled it when it was starting, saved it normally and now it won’t let me see it. I don’t understand why! Anyone got any idea of what to do? Thank you,
    Salva
    John Bolton replied 6 years, 4 months ago 2 Members · 2 Replies
  • John Bolton
    April 29, 2020 at 12:57 pm
    if you are on Windows 10 then maybe the Controlled Folder access switch is ON within Windows Security. If that is the case you can either move the switch to Off or add the Folder you are trying to get access to. During my last Windows 10 updates it turned back on .
  • John Bolton
    May 2, 2020 at 7:39 am
    Did you solve your problem.. Would be good to know
