Activity › Forums › VEGAS Pro › ”An Error Occurred While Creating Media File” – FIX – Video Tutorial
  • ”An Error Occurred While Creating Media File” – FIX – Video Tutorial
    Posted by Kielan Jepson on January 11, 2013 at 11:56 pm
    https://www.youtube.com/watch?v=3Jxi2prAmLs
    Ok guys, I know quite a lot of people can encounter this annoying error which stops them from rendering 1080p mp4 videos, which is bad if your rendering for youtube HD etc.
    Anyway, the simple fix In my video tutorial allows you to completely fix this problem in a matter of seconds 🙂 I cant tell you how relieved I was when I found this out.
    Kielan Jepson replied 13 years, 8 months ago 3 Members · 3 Replies
  • John Rofrano
    January 12, 2013 at 2:13 pm
    [Kielan Jepson] “Anyway, the simple fix In my video tutorial allows you to completely fix this problem in a matter of seconds 🙂 I cant tell you how relieved I was when I found this out.”
    Yes, The standard recommendation for debugging render problems is to disable the GPU acceleration and render using CPU only to see if it fixes the problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    January 12, 2013 at 5:35 pm
    I’ve read this elsewhere too.
    Disengaging the GPU appears to work for many people.
    What card are you using?
    Cameras: Canon XF300 and two elderly XM2s
  • Kielan Jepson
    January 12, 2013 at 7:14 pm
    I dont actually experience the problem myself, but when I did I was using a nvidia geforce 9200m
    Now Im using an ATI RADEON HD 7970 and It works perfectly
