Activity Forums Adobe After Effects An efficient way of Gradient Ramp Scale dots grid
  • An efficient way of Gradient Ramp Scale dots grid
    Posted by Adam Lewen on January 4, 2020 at 3:11 pm
    Hi there!
    I am looking for help, tips, thought;
    I am crating animations where the BG is based on a grid of dots, a LOT of dots
    They all carry a scale expression controlled by a gradient ramp
    The render is VERY heavy. It’s frustrating.
    I am looking for methods of getting a similar idea visually, in a different way.
    I am sure there is one!
    Thanks so much!
    Adam Lewen replied 6 years, 8 months ago 2 Members · 2 Replies
  • Matthew Keane
    January 4, 2020 at 4:13 pm
    Not sure if you want to go down the plug-in route, but they will probably render faster than thousands of scale expressions.
    If it were me, I’d use the Trapcode Form plug-in to do this – set up a grid of dots, tell it to use your gradient as a layer map to affect scale/opacity of your particles and then tweak until it looks the way you like.
    On the other hand if you don’t have access to third-party plugins, maybe the built-in CC Ball effect can achieve something similar. I haven’t used it in a long time, but I seem to remember you can use a layer to affect the particles in a similar way to Form.
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Media Server Programming & Live Operation.
  • Adam Lewen
    January 4, 2020 at 7:19 pm
    Thanks so much Matthew!
    Spot on! great tip. They have access to the plugin!
    what a difference!
    good weekend!
