An easy one – How to render NTSC wide (1.2) project for web use
Hello,
I have what I hope is an easy question. I have an AE project that uses widescreen DV. The entire project is in NTSC widescreen PAR. I typically dump these straight to DVD for distribution so I never worried about pixel aspect ratios before. Now I’m starting to post projects on a website which means square pixels are used. So, how do I render my 1.2 PAR comp so it displays correctly on the web?
My best guess is to use the stretch checkbox when I render and put it to 854X480. Is that the right approach or am I missing something?Thanks
Gary
