Activity › Forums › Adobe Premiere Pro › An alternative to recovering corrupt premiere files
  • An alternative to recovering corrupt premiere files
    Posted by Omer Cete on March 21, 2013 at 11:52 am
    I just wanted to share it may help someone in the same situation.
    Yesterday we finished a 15 day, day&night working project.
    Today we came to the studio and the project file and 5 autosave files are corrupt!!!! they are not opening, giving every wierd error code. Searched the web, no solution, importing to a new project, after effects, just copying the file somewhere else offlining everthing, nope!
    We made a short render 1 day back with media encoder. so in
    Users…AppData-Local-Temp I found that prproj file and lost only 1 days work.
    so what I learned;
    -always use media encoder
    -if working on the same file for days, weeks, make copies with save as and increase the version number, continue working on the new file
    – there is a copy of every encoder rendered prproj file under Users…AppData-Local-Temp
    Joe Barta iv replied 13 years, 6 months ago 3 Members · 2 Replies
  • Petros Kolyvas
    March 21, 2013 at 5:27 pm
    i wonder if you’re having the same issue that I had. (https://forums.creativecow.net/thread/3/936325)
    Did you use any audio filter effects (and then maybe update the plugins?)
    I had an issue where all project files (autosaves, previous and alternate versions, etc.) were all listed as corrupt or “an error occurred”
    I opened then on another workstation here that doesn’t have any audio plugins and it it worked fine. I stripped out all the audio plugins from each sequence and it would then open on the original workstation.
    I wonder if this issue extends to any other plugins/utilities.
    Premiere definitely needs a little more gracious error handling!
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • Joe Barta iv
    March 21, 2013 at 7:30 pm
    Thanks for putting this info in the forum. I haven’t run into that error yet, but if I do, I know I can now search for the workaround here.
    Bars & Tone
    SALUTE!
