Activity › Forums › Corporate Video › Amsterdam NTSC shoot with 50Hz lighting question.
Posted by Mike Hennessey on April 26, 2006 at 6:16 pmI have a corporate video shoot coming up in Amsterdam. It
Richard Spanswick replied 20 years, 3 months ago 2 Members · 4 Replies -
Richard Spanswick
May 2, 2006 at 6:20 pmHi,
I’m new to this forum, so forgive my unannounced intrusion, but have some experience of this problem in reverse.
A few years ago I brought a PAL VX1000 to the US to shoot a documentary. I failed to take into account the 50hz/60hz issue and had some footage which exhibited strobe. I could have solved it by using the camera’s 1/60 shutter speed.
My take on this is that you are almost certain to get strobe under fluorescent lighting – which may be quite irritating to watch – but probably little that is noticeable with standard tungsten bulbs. Using the 1/100 shutter speed should help – but of course the trade off is the requirement for higher light levels. In my experience, the ambient lighting levels in a lot of hotel ballrooms are barely adequate for video at the best of times. Maybe the best thing to do is to allow time before the shoot begins to experiment in the venue and then pick the optimum solution.
Good luck with the shoot.
Richard
Mike Hennessey
May 3, 2006 at 4:43 pmThanks Richard, I got a few more details. I just found out that the lighting at the hotel is all 50 watt halogen lamps. So what do you think, will I get the big nasty flicker? We arrive 2 days early and plan to do a test first thing. If it fails we will rent cameras over there. Can you recommend a rental house in Amsterdam?
Thanks -Mike
Richard Spanswick
May 4, 2006 at 4:56 pmMike,
I had a quick look on Google and found this site:
https://www.alrad.co.uk/datasheets/FAQ003-Illumination.PDF
About halfway through it mentions the problem with halogen and flicker, if you’re not using 25fps cameras. I don’t really know enough about the technology to be able to estimate how much flicker you’re likely to get with any given light source. The problems I had were mainly in a parking lot at night, which I assume was lit using metal-halide lamps. I suppose you have to weigh up whether shooting in PAL and then transcoding to NTSC is likely to give better results than accepting a certain amount of flicker (or possibly adding gain to compensate for inadequate light levels when shooting 1/100).Unfortunately, I have no experience of rental houses in Amsterdam – we always took our own equipment from the UK when shooting in the Netherlands. I now live and work in Oregon.
I hope you manage to solve the dilemma!
Richard
Richard Spanswick
May 4, 2006 at 5:11 pmMike,
If your final output is to be NTSC, have you considered hiring a camera (NTSC) with extended clear-scan that will allow you to reduce the scan rate to 50? I don’t know if there are any trade-offs in the form of visible smear/blur – but if you are thinking of hiring anyway, it might be worth investigating.
Richard
