Activity Forums Adobe After Effects Ameteur greenscreen key with stop-motion
  • Ameteur greenscreen key with stop-motion
    Posted by David Goodwin on November 16, 2016 at 10:22 pm
    Warning: Pretty inexperienced using After Effects
    So to test it out I recorded a very short brickfilm sequence with green card behind to act as a mini greenscreen. I have no additional lighting available apart from the room light and an omnidirectional touch table lamp (not used). I used to have more lighting, again fairly basic, but I don’t have access to it at the moment and the results were the same with it.
    Without key:
    With key, I used a random background image off Pixabay:
    Admittedly the lighting environment is dreadful which may be a factor but I don’t want to keep buying things just because I don’t have access to them.
    Could this be corrected in the camera or AE? I manually white balanced it, macro on and camera on Program mode. Compact Nikon Coolpix S9700. I’d upload GIFs of the sequence but had trouble exporting.
    Alex Lindblom replied 9 years, 9 months ago 3 Members · 2 Replies
  • Michael Szalapski
    November 17, 2016 at 5:43 pm
    If you’re looking to key your image, there are a few ways. I’ve made three example attempts here with Color Range, Keylight, and copies of the obsolete Color Key effect. So, turn one example off in the layer stack, turn another on, and take a peek. 10806_legokeying.aep.zip
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Alex Lindblom
    November 17, 2016 at 7:11 pm
    I managed to pull an okay, fast key with only using…
    Screen gain — 130
    Screen Balance — 50
    Then
    Clip White — 8
    Screen softness — 5
    But since you have the original footage you will probably get away with less softness.
    And now the most important part.
    Replace Method — Source
    It’s the soft color choice that introduces the artifacts you see on your key. So I would say in 99% of the cases use the “Source” option for Replace Method.
