Activity Forums Adobe After Effects america’s physic challenge footage effect
  • america’s physic challenge footage effect
    Posted by Raine Parrish on March 2, 2008 at 5:26 pm
    Hello All,
    I’d like to treat some footage with the effects they did for the physic challenge episodes. Heavily effected- in particular I’m looking at the layer, almost old photograph frame they’s got on some of the footage. I’m wondering if this is a plugin they’ve used? The edges are dark- the footage palying inside the “soft edge “hole” that’s cut out.
    Here’s a link – for the first full length episode.
    If anyone knows of the plugin- or can suggest how to create this great layed look, I’d appreciate it.
    BTW- tried my hand at a few layer masks- but when I feather the edge to create that great opacity blend they have going- mine just looks to wispy.
    Using a PC, win 2000, AE 6.5.pro.
    Here’s the link:
    ” target=”_blank”>https://videos.lifetimetv.com/?fr_story=bcf574948fe5e4232b82e0a7ece36347dade9caf&rf=bm%20
    r
    Chris Heuer replied 18 years, 6 months ago 3 Members · 5 Replies
  • Thomas Leong
    March 2, 2008 at 6:35 pm
    Here’s a guess –
    They used Magic Bullet Looks (from redgiantsoftware.com)
    – probably with Looks > Special Effects > Benumbed, with added side Grad Exposure tool
    – and Looks > Black & White Tint > Black and White Crunch
    and then keyframed to super bloom when required.
    Thomas Leong
  • Raine Parrish
    March 2, 2008 at 7:16 pm
    Thanks much for reply.I’ve got the older version of MAgic Bullet Suite, V 2.0- but all I’ve ever seen in the looks department are the preset looks. HAve never seen a special effects slot. Maybe I’m overlooking something? Or it’s new to the more current versions.
    I wonder if there’s a way to create it with solid layers and noise? I’ll keep trying!
    r
  • Thomas Leong
    March 2, 2008 at 7:54 pm
    The ‘Special Effects’ is one of the presets in Looks v1.0, now part of Suite 2007. I’ve only got Looks, not the Suite. I think there is an upgrade price for your Suite v2.
    Alternative is to download the demo of Looks v1.0, check out the components that I had a ‘guess’ at, and see if you can duplicate it with your Suite.
    Thomas
  • Raine Parrish
    March 2, 2008 at 8:00 pm
    Thnaks Thomas- I’m running win2000 so I can’t run the new Looks- was looking at the site- so I’ll have to do it the bast I can by layering stuff and playing with noise and try some masking.
    Thanks much
    r
  • Chris Heuer
    March 3, 2008 at 1:30 pm
    Try Andrew Kramer’s Film Magic Pro (6th down). It’s a bunch of Color style presets for AE and only $50.00! Also Check out Riot Gear. It has Grungy textures you can use for cutting a hole with gritty edges. Both disks will cost you WAY less than Magic Bullet (and the Presets render much faster!)
    Good luck, Chris
    Chris Heuer
    Freefall FX, LLC
