Activity › Forums › Adobe Media Encoder › AME Target Bitrate LESS than .19 Mbps
  • AME Target Bitrate LESS than .19 Mbps
    Posted by Christopher Jarvis on October 25, 2020 at 9:01 am
    Hey everyone, the slider for h.264 in AME goes to .19 minimally. I’d like to go lower. I’ve tried manually reducing it in the input box but no luck. Any ideas / suggestions? I see no reason why the encoder couldn’t do this, is it simply a UI issue? It seems silly I can’t do this… Thanks!
    Christopher Jarvis replied 5 years, 11 months ago 2 Members · 2 Replies
  • Andy Ford
    October 30, 2020 at 12:19 am
    It’s a restriction of the profile and level, just as you can get different max bitrates by changing the profile and level. If you use level 1, the minimum bitrate reduces to .06.
  • Christopher Jarvis
    October 30, 2020 at 2:24 am
    This was very helpful, thanks Andy!
