Activity Forums Adobe Media Encoder AME still wont open..
  • AME still wont open..
    Posted by André Bertel on June 4, 2014 at 8:44 pm
    Hello,
    After some tryouts in different formats I found .avi that was clearly the best. But, since it’s not compressed 30 seconds would most likely me 5+ gigabytes. So H.264 which I’ve used for some time (when I had AAE 5.5) would be the best. But as I have AAE CC now it’s not a opportunity. At least not using After Effects own render feature. But when trying to open Adobe Media Encoder nothing, and I mean, NOTHING happens!
    It seems like I’m not the only one having this problem. I really dont want to reinstall AAE and APP. Are there any other Render softwares out there that can take H.264 or mp4?
    PC Specs:
    Intel Core i7
    8GB RAM
    500GB Seagate HDD
    1TB Seagate SSD
    Gainward GTX770
    Gigabyte Motherboard MB1155
    Windows 8.1 Industry Entreprise
    https://imagizer.imageshack.us/v2/640x480q90/841/59qdg.jpg
    Thomas Nord replied 12 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    June 4, 2014 at 9:53 pm
    What problem, exactly, are you having with Adobe Media Encoder? The more details that you give about what exactly you are doing and experiencing, the more likely we can help.
    After Effects team blog
  • André Bertel
    June 4, 2014 at 9:56 pm
    When I try open it, nothing happens. Neither with administrator.
  • Thomas Nord
    June 4, 2014 at 11:39 pm
    André,
    Just to clarify, can you open AME directly (not initiating it through After Effects)? If it still won’t launch for you that way, can you please try holding the Shift key as you launch it? Has it ever been able to launch successfully? If it has, please try rebooting your system and then launching.
    Tom
  • André Bertel
    June 5, 2014 at 7:52 pm
    Shift doesn’t fix it. It doesn’t start when opening it from AAE or directly from its shortcut. I has worked, but after some time not using it, it suddenly stopped working.
  • Thomas Nord
    June 6, 2014 at 4:36 am
    Ok, let’s try deleting your media cache.
    Go to :\Users\\AppData\Roaming\Adobe\Common. Delete both “Media Cache” and “Media Cache Files” folders while no Adobe apps are running. Now try to launch AME.
    Also, can you confirm that Adobe Media Encoder does indeed show up in Control Panel > Programs and Features. I want to make sure the system sees it as being installed.
  • André Bertel
    June 6, 2014 at 3:27 pm
    Deleting Media Cache and Media Cache Files doesn’t change anything. It doesn’t show up in Programs and Features.. Can I install it manually?
  • Thomas Nord
    June 6, 2014 at 11:51 pm
    I’m afraid if it isn’t showing up in Programs and Features then the system doesn’t see it as being installed even though there are apparently files on the disk. At this point a reinstall is probably required. To do so, you will need to uninstall any app that installs AME (After Effects, Premiere, Prelude) then reinstall them. You could try just uninstalling/reinstalling Premiere but if that doesn’t work you will need to do them all. The next version of AME will have it’s own installer so this type of workaround won’t be necessary in the future.
