Activity Forums Adobe Premiere Pro AME Export Problem.
  • AME Export Problem.
    Posted by Gary Hallquist on October 24, 2008 at 2:26 pm
    I have 59.94 HD footage. I edit it, export it through Adobe Media Encoder to Mpeg-2 DVD at 29.97, drop-frame, lower field dominance. I then import that .m2v file into Encore, and then export to DVD, without re-transcoding or encoding anything. The DVD plays back with a 24p-like jitter, or blur to it. I do not understand this. After encoding the .m2v file, I went back and played that on windows media player, and other media players, and the video played back as it should originally, very smooth. Why is it that in between creating the .m2v and exporting the DVD in Encore, I am getting this 24p-like blur/jitter to the video? Does it matter that some of these videos I am putting to DVD-DL and are quite large? Hope someone can help. Thanks. Any other info needed, I will supply for you.
    This has occured on both an SD and a HD project.
    Souce clip was JVCPro HD AVI @ 59.94, 60i, lower field, 1280×720.
    Here’s the SD specs:
    29.97, 720×486, lower field, DV format.
    Edited in a timeline that matches the above specs, which is SD.
    Vince Becquiot replied 17 years, 10 months ago 2 Members · 1 Reply
  • Vince Becquiot
    October 25, 2008 at 3:57 am
    How long is the video?
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
