Activity › Forums › Adobe Media Encoder › AME CS6 Question: How to Update Estimated File Size?
  • AME CS6 Question: How to Update Estimated File Size?
    Posted by Jan Janowski on August 2, 2018 at 10:25 am
    This refers to CS6 version…. Specifically AME called up within Premiere Pro CS6…
    I’ve noticed that when I EXPORT Media from Premiere Pro Using AME, That the current settings in place when AME is opened calculate an Estimated File Size…. Good!
    If I change to a different format…. That Format changes the Estimated File size… Good!
    However, if I change quality or other settings Within the selected format, The estimated file size DOES NOT CHANGE with the change in settings…
    Is there a way to have AME Update this to reflect the estimated file size based upon the changed settings?????
    Again, we are talking CS6 Master Collection versions….
    Jan Janowski replied 8 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
