Activity Forums Adobe Premiere Pro AME CC creating duplicate files from .mxf sources
  • AME CC creating duplicate files from .mxf sources
    Posted by Chris Borjis on July 31, 2013 at 1:17 am
    Panasonic p2 .mxf files that a client needs converted to .mpg files.
    I drop them in AME CC (mac) and when I do add one at a time
    or as a group, even though they all have unique names, it
    is showing them as duplicates of others and the content is duplicated as well
    when I check the source.
    Seems to do it even if I do them separately.
    example:
    I drop in a file called 001E4.mxf
    then drop in 004RT.mxf, but ame renames it 001E4.mxf and the destination
    file as 001E4_1.mpg If I look at it in the preset window preview it shows
    as the same content as the first…but should be something else.
    what in the world is causing that?
    I did have an older version of Calibrated MXF installed, but
    removed it and rebooted…same problem.
    Chris Borjis replied 13 years, 1 month ago 1 Member · 1 Reply
  • Chris Borjis
    August 2, 2013 at 4:35 pm
    I was trying to open them and encode to and from a usb drive.
    copied to my RAID storage and problem is gone.
