AME – Adobe Media Encoder CC Benchmark 4K to 1080p
So I decided to do my own research on “brute encoding speed” of graphic cards in Adobe Media Encoder.
Here is the file you need:
https://docs.google.com/uc?id=0B24xtHi28gsJem1kb3NGQVdaSzQ&export=downloadIt’s a 4K 60mbs .mp4 file.
Open it in AME and encode it to the followeing settings:
– Format: QuickTime
– Settings Custom:
Video Codec: PHOTO – JPEG
Quality: 95
Res: 1920 x 1080
Framerate: 25
Enable/check: Render At Maximum Depth
Enable/check: Use Maximum Render QualityI know that for some of you has this no meaning, but for me it does.
You can use Nvidia, AMD, Intel, anything you want, just write it down.Post your results like this:
CPU: 4930K @ 4.2GHz
RAM: 16GB – 1866MHz
GPU: GTX 770 – 2GB OC
Rendered: CUDA
Win 8.1 – 64bit – AME CC 2014
From HDD to SSD
Time: 0m 38sThaaaank you very much! I’ll post results later.
