Activity Forums VEGAS Pro AMD vs Intel
  • AMD vs Intel
    Posted by Tyrone on December 23, 2005 at 7:32 am
    Hiya
    I am setting up an HDV edit suite and also want to run Combustion and After Effects. I have been told that the most important element is processing power and RAM for combustion. So to fit my needs perfectly do I go AMD dual core or Intel dual core. Is 2 gig RAM sufficient? What graphics card (resenably inexpensive and dual display) would be ideal. And any other suggestions welcome. Which versions of Sony Vegas have HDV support as just found out my version of Premier does not? I have worked with Premier Pro and Sony Vegas, I know Premier Pro has multiple timelines but it seems Vegas only has one timeline available, is this true?
    Thanks very much
    Tyrone
    Edward Troxel replied 20 years, 9 months ago 4 Members · 4 Replies
  • George Loch
    December 23, 2005 at 5:06 pm
    [Tyrone] “do I go AMD dual core or Intel dual core”
    No question at this point. AMD dual core is faster.
    [Tyrone] “Is 2 gig RAM sufficient?”
    Should be fine but, that depends on what you are doing.
    [Tyrone] “Which versions of Sony Vegas have HDV support”
    The platinum verion of Vegas Home studio and Vegas 6 both support HDV.
    [Tyrone] “I know Premier Pro has multiple timelines but it seems Vegas only has one timeline available, is this true?”
    Vegas 6 only supports one timeline per project but you *can* import multiple projects into another. Not as ideal as the multiple sequences in PPro or FCP but it’s better than nothing. Let’s hope Vegas 7 comes out with a real solution.
    -gl
  • Gary Kleiner
    December 23, 2005 at 6:31 pm
    [George Loch] “Vegas 6 only supports one timeline per project”
    Don’t forget that you can open mutiple copies of Vegas at the same time. Something no other NLE software does.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • George Loch
    December 29, 2005 at 3:46 pm
    [Gary Kleiner] “Don’t forget that you can open mutiple copies of Vegas at the same time. Something no other NLE software does.”
    While this is true, it’s a very ineffcient way to handle the need. It means your loading a completely new instance of the whole program. This seems pretty expensive resource-wise for this functionality.
    -gl
  • Edward Troxel
    December 29, 2005 at 3:54 pm
    [George Loch] “It means your loading a completely new instance of the whole program. This seems pretty expensive resource-wise for this functionality.”
    If you open the Task Manager, you’ll see it’s much less than you’d expect. Way less than double. I’ve heard of people that routinely have 5, 6, 7 instances open.
    Edward Troxel
    JETDV Scripts
