Activity › Forums › Adobe After Effects › AMD Radeon 780M can use element3D ?
  • Hector Vera
    April 15, 2024 at 6:30 pm
    That AMD Graphics card seems to be one of the more recent releases from AMD on January 2023. I would imagine it should be compatible with Elements 3D since it supports a lot of the older Graphics cards before 2022. Here is more info on the GPU just incase: https://www.techpowerup.com/gpu-specs/radeon-780m.c4020
    That pdf file you provided seems to be from before 2022 since 780M was not on the list at the time. And I found a 2022 list and it was not there either. Best of luck!
  • Nutdanai Rhusuwankul
    April 17, 2024 at 2:19 am
    I ask to support videocopilot too , and answer is ‘ integrated graphics that is part of the CPU ‘ not support E3D. 😭 what a sad day.
