Activity Forums Avid Media Composer AMD and Quadro FX
  • AMD and Quadro FX
    Posted by Jhones on May 28, 2007 at 10:28 am
    hi.
    i have this AMD at work dual proccesors 3800+ and xpress HD 5.5 with Mojo SDI and Nvidia Card 6200.
    this PC restart himself while editing once a while.
    i anderstand Avid dont like AMD. and a friend of mine tald me to get a Quadro FX card which can help. is that true?
    second one, another PC same specs whithout Mojo and the sound volume is low.
    what audio card do u recomand for this?
    thx in Advance
    Michael Hancock replied 19 years, 3 months ago 3 Members · 5 Replies
  • Jhones
    May 28, 2007 at 3:17 pm
    need to clear things…
    the soundblaster card that we can get now is 5.1 or 7.1 only is that good anough?
  • Rhewitt
    May 29, 2007 at 12:15 am
    Firstly, you need to check the specs supported for the application. Only these are guaranteed to work but does not mean other setups will not work.
    There’s no truth in the belief that Avid don’t like AMD. It all goes down to the way the processor operates and if it works with the application. The AMD Opteron processor is on the supported workstation list.
    Avid Specs for XPress are here.
  • Jhones
    May 29, 2007 at 5:26 am
    ye i know that. too bad my boss didnt knew that….
    im trying to close some holes now.
    how about the quadro 560fx is it worth to spend this money (250$ in israel) to upgrade the nvidia 6200? what basicly the benefits r?
    second.. i understand SoundBlaster is the recommended card for audio
    here we have 5.1 or 7.1 wich one will u go for?
    thx
  • Rhewitt
    May 30, 2007 at 2:18 am
    Only the following NVidia cards are qualified by Avid:
    NVIDIA QuadroFX 3500 PCI Express
    NVIDIA QuadroFX 3450 PCI Express
    NVIDIA QuadroFX 3400 PCI Express
    NVIDIA QuadroFX 1500 PCI Express
    NVIDIA QuadroFX 1400 PCI Express
    NVIDIA QuadroFX 1300 PCI Express
    NVIDIA QuadroFX 560 PCI Express
    NVIDIA QuadroFX 550 PCI Express
    NVIDIA QuadroFX 3000 AGP 8X
    NVIDIA QuadroFX 1100 AGP 8X
    NVIDIA QuadroFX 500 AGP 8X
    Each card moving up the range has the ability to handle more complex on-screen FX and renders. The 560 is pretty much bottom of the current range. I would suggest something more like the 1300-1500 range if you want to work with HD media.
    As for the sound card, most people have success with the Audigy 2 version. Avid qualified sound cards are required because the editing application needs to take control of the card to ensure the sound keeps in sync – most sound cards don’t allow this and is the primary reason for audio related problems.
  • Michael Hancock
    May 30, 2007 at 2:31 am
    RHewitt is dead on with the graphics card–buy the best approved card you can. Your system will thank you for it, and the likelihood of your system being outdated in the next release won’t be so great.
    Regarding sound cards–the Audigy 2 works, and it’s cheap. The ironic thing about Avid–they don’t have a list of qualified sound cards like they do with the graphics cards. Unless you find out from your reseller or on a forum like this, you don’t know what to get. Huge oversight on Avid’s part.
    Regarding AMD processors. The only system they’re approved for is the Symphony, maybe the DS. From Media Composer on down the only approved processors are from Intel. Some have had success with their AMDs, many do not. What works for you now might not work after the next upgrade, so beware of that. Running an unapproved system can lock you to certain versions of the software.
    Michael.
