Amd 8350
Posted by Thayalan Paramasawam on January 10, 2014 at 1:04 amHi morning,
I am using AMD processor 8350,16gb ram,graphic card asus gtx 650 and operating system win 7 pro 64 bit.For render Avchd (mts file) its take 2 hours to render 1 hour 20 minute project.
Pls give me some suggestion to make more faster the rendering time.Thank you
Thayalan ParamasawamStephen Crye replied 12 years, 7 months ago 3 Members · 8 Replies -
Norman Black
January 10, 2014 at 3:51 amThat render time is about right from my limited experience with Vegas encoders.
You can try Mainconcept AVC CUDA. That will not be an AVCHD file. It will be MP4 with AVC video and AAC audio.
Norman Black
January 10, 2014 at 5:47 amI did not mention Intel Quicksync since you have an AMD CPU.
Intel Quicksync will be faster than any of the other encoder options in Vegas. To use Quicksync in Vegas you must use the Sony AVC encoder.
Another thing. Sony AVC is much faster than the Mainconcept AVC.
January 10, 2014 at 6:47 amThank you sir for reply…….actually i am using amd for video editing (3 working station)….but after i saw some forums regarding w.station,i think my amd having some probleums.so i post this question to solve my probleum…speed up my amd but after your adivice i need to change to intel to save my time.
Because i have to render many projects (1 hour 20 minutes) everyday.Thank you
Thayalan Paramasawam -
Norman Black
January 10, 2014 at 5:18 pmUsing Quicksync can be a little quirky when you also have an AMD/Nvidia video card installed in the same machine.
In such a situation you must have the video drivers installed for both Intel and the other AMD/Nvidia card. If you have only one monitor and that is hooked up to the AMD/Nvidia card you will have to take measures to get the Intel functioning.
Here is a link with some info
https://mirillis.com/en/products/tutorials/action-tutorial-intel-quick-sync-setup_for_desktops.htmlAnother option is if your monitor has multiple inputs. You can connect the video card and Intel to the same monitor and just not use the Intel input.
It is a pain if you have an AMD/Nvidia card and want the Intel graphics only for Quicksync, but it can be done.
January 11, 2014 at 12:47 amThank very much sir for adivice me…….i will feed back to you after use the steos you given…..
January 13, 2014 at 1:38 amHi morning sir,
Thank you sir…..after i do sync……i improve my rendering speed.
Thank you -
Stephen Crye
January 23, 2014 at 3:33 am[Norman Black] “Another thing. Sony AVC is much faster than the Mainconcept AVC.”
I’ve been doing benchmarks like crazy the last week, using the “red car” project. My times are consistently shorter with MainConcept AVC than Sony AVC.
For example, tonight, after trying something strange (I left the window open to chill down my computer room to start with a cold GPU, yes, I am odd), I was able to get the render down to 3:08 with MainConcept CUDA, but Sony with “GPU if available” or “Automatic” was 3:28.
Steve
Win7 Pro X64 on Dell T7500, MultiTB SATA, 8GB RAM, nVidia Quadro 2000, Vegas 12, 11, 10, 9 DVDA 6.0 & 5.2(build 135) Sony HDR-CX550V, Panasonic GH3 with LUMIX G X VARIO 12-35mm / F2.8 ASPH, LUMIX G X VARIO 35-100mm / F2.8
