Activity Forums Avid Media Composer AMC 6 . MTS Problem
  • AMC 6 . MTS Problem
    Posted by Lloyd Paul rivers on April 23, 2012 at 5:58 pm
    Out of about 400 .MTS clips 2 or 3 say they wont import. The import bar gets to around 99.9% then i have an error that says Exception: DISK_DIR_NOT_FOUND, filename:Performance 2.MTS
    When i try and link via ama it says There were errors linking AMA files. See the console for details. What is the console? Sorry to sound dumb im a first year editing student, currently on break and my lecturers are not contactable.
    One of these clips is a 49 min stage performance which i desperately need.
    Any input would be appreciated
    Many Thanks
    Lloyd Rivers
    Lloyd Paul rivers replied 14 years, 4 months ago 2 Members · 4 Replies
  • Juan Salvo
    April 23, 2012 at 6:35 pm
    try using mpegstreamclip to extract as much as you can. Seems the files are corrupted.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Lloyd Paul rivers
    April 23, 2012 at 6:41 pm
    Tried MPEG stream clip it kept crashing towards the latter part of the process. Got it sorted now i used handbreak.
    Any reason for the 1 file in over 400 to become corrupt?
    Many Thanks
    Lloyd Rivers
  • Juan Salvo
    April 23, 2012 at 6:45 pm
    Too many reasons. Bad media / bad file copy. 1 out 400 ain’t bad.
    Did you run repair timecode breaks in streamclip?
  • Lloyd Paul rivers
    April 24, 2012 at 2:41 pm
    No i didnt know i could. Fun times now, when i try and export the sequence it says its in an unsupported codec
    Update: it says No valid resolution found to be exported using same as source
    Many Thanks
    Lloyd Rivers
