Activity › Forums › Maxon Cinema 4D › Ambient occlusion was on and working fine, now it is off and I cannot turn it back on
Posted by Jon Simpson on July 14, 2014 at 12:26 amYeah, so when I go into render settings and click on ambient occlusion that is checked, I get a blank screen, no options.
Jon Simpson replied 12 years, 1 month ago 2 Members · 4 Replies -
Jon Simpson
July 14, 2014 at 12:30 am -
Jon Simpson
July 14, 2014 at 2:38 amCorrection, it is still on apparently, but it is NOT rendering accordingly, and the options to control it are not there.
Brian Murphy
July 14, 2014 at 5:35 amLooks like you have activated it for the Multipass feature. This ONLY allows you to save a pass of the ambient occlusion however you have to activate the actual effect.
So next to the “Multi-Pass” button in your render window, you’ll see an “Effect” button, click on that and you will see “Ambient Occlusion”. Select it. This is where you will adjust your settings. This ‘effect’ has to be active for your AO multipass to render.
Hope that helps.
Brian -
Jon Simpson
July 14, 2014 at 8:13 pmThanks Brian, it was already activated. It is not rendering though. I have checked my settings and everything is right. It was working and suddenly stopped.
