Activity Forums Maxon Cinema 4D Ambient illumination render issues – pixelated
  • Ambient illumination render issues – pixelated
    Posted by Chris Shaw on August 31, 2013 at 12:36 pm
    Hi I’m working on a project for a client which is going to have a “flat” look to it. I’ve decided to use ambient illumination in order to create this look. The problem is the shadows look awful and very pixelated. Does anyone know a solution to this?
    Thanks in advance,
    Chris
    David Pocull replied 12 years, 10 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    August 31, 2013 at 5:16 pm
    You’re talking about the line between the light and shadow? If so I wonder if it might help to use a small area light instead of an Omni?
  • Chris Shaw
    September 10, 2013 at 11:16 am
    Hi Adam,
    Thanks for your reply. No matter what light type I use I still get the same results but only on objects that in Hyper Nurbs and also using the metaball.
    Below is an image taken where you can see the difference. The sphere on the left is a parametric object that hasn’t been changed to a polygonal object (before it’s ‘made editable’) and the object on the right is an object in a Hypernurbs object. I’ve added a compositing tag on to the object on the right to try and smooth out the shadow by setting the anti-aliasing up to Best (Min 1×1, Max 4×4).
    The reason I’m using this workflow is I’m trying to get the perfect “flat” look for a current project. Here’s an example of the style I’ve done using parametric objects https://vimeo.com/74154760 password: sell
    The huge problem is the animation is going to have characters etc that will be using hypernurbs and right now that’s just not possible with such awful pixelation on the shadows.
  • David Pocull
    November 13, 2013 at 9:40 am
    Hey Chris, I have the same problem with the shadows using the ambient illumination.
    Did you managed to find a solution?
    Cheers!
