Activity › Forums › Adobe After Effects › Amazing Look
  • Amazing Look
    Posted by Joe Pallagio on November 28, 2007 at 1:01 am
    I am making a music video where we are after a specific look. The look is somewhat like this here. https://www.renaissance-lefilm.com/espacepresse.htm
    We have been trying Live Trace in Illustrator with some promising results, but I was wondering if anyone has any ideas about an After Effects, plugin, or some other way to recreate this sort of look based off of live footage. This film used 3D so they had full control with toon shaders and such, but solving the question for live footage is the current issue. If you have any ideas it would be greatly appreciated. Thanks in advance.
    Joe Pallagio
    Aharon Rabinowitz replied 18 years, 10 months ago 4 Members · 3 Replies
  • Darby Edelen
    November 28, 2007 at 5:13 am
    I think a lot of it would start during pre-production planning and shooting. For example, it will be easier to separate areas of light and shadow if there is more contrast between them. Consider running some tests with a low-key lighting setup with a high key to fill ratio.
    Once your test footage is in AE I would look at the Layer > Auto-Trace tool, which is basically a Live Trace that can be applied to the entire length of your workspace. Here’s some info from Adobe’s exhaustive help files:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS65568770-F022-4c7e-89F4-AC9F2E563386.html
    Using the luminance for the Auto-Trace is a good place to start, but you could also look at each RGB channel of your footage independently and use one that more closely approximates the contrast you require.
    You will want to apply the Auto-Trace to a new solid layer (an option in the Auto-Trace dialog) so that the masked areas correspond to areas of solid color instead of the RGB of the original footage.
    The other note to add to this is that you should consider doing several Auto-Traces at different thresholds to develop a more posterized black-to-gray-to-white look. Off the top of my head, if you were going to use 3 shades of gray I would think to try auto-tracing with well distributed thresholds like 230, 200, 170. Then set each of your Auto-Traced solid layers to 33% brightness and use an additive blend mode (Add/Screen).
    I can’t stress enough how important it will be to run some tests of the workflow though.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Steve Roberts
    November 28, 2007 at 6:28 pm
    I think this piece has been discussed before. Try searching the AE COW for “renaissance”.
  • Aharon Rabinowitz
    November 28, 2007 at 7:51 pm
    If you haven’t looked at Digital Anarchy’s ToonIt! you should. It’s a toon making plugin for AE, and it does a much better job of ignoring the noise and slight color changes that mess up livetrace.
    https://digitalanarchy.com/toon/toon_main.html
    It might be able to it, but I’m not sure.
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
