Activity Forums Avid Media Composer AMA Workflow Question
  • AMA Workflow Question
    Posted by Chip Hess on June 28, 2015 at 8:38 pm
    I am on MC 6.5.4
    I have DNXHD 145 720 59.94 footage.
    I import the footage via AMA, cut my sequences.
    Then, I consolidate and transcode the sequences
    to allow me to export reference movies for Sorenson.
    Is this best practice workflow?
    I ask as the footage already is recorded on an AJA at the same codec and frame rate I am using for the project.
    Is both consolidation and transcoding necessary, or is there a better way?
    Chip Hess replied 11 years, 2 months ago 2 Members · 2 Replies
  • Michael Phillips
    June 28, 2015 at 9:15 pm
    You got it – if the source codec is considered “native” to Media Composer, then you should be able to just consolidate. If not, then you need to transcode as well in order to export a “same as source” for encoding in a third party application.
    Michael
  • Chip Hess
    June 28, 2015 at 9:30 pm
    As suspected, thanks Michael!
