Activity › Forums › Avid Media Composer › AMA QTref
  • Posted by Stig Olsen on March 23, 2012 at 12:27 pm
    I have noticed that even after transcoding AMA-material on the timeline I have problems exporting QT-reference.
    What is this all about? I have also noticed that if I move the part I want to export on a new timeline, everything works well.
    Avid. 5.5
    Stig
    Michael Phillips replied 14 years, 6 months ago 3 Members · 2 Replies
  • William Busby
    March 24, 2012 at 4:28 am
    Since you don’t say what the problem is… I’m guessing your sequence may be Long GOP related? Which you should probably look into https://www.calibratedsoftware.com/QXDSpecs.asp. Just a hunch.
  • Michael Phillips
    March 24, 2012 at 11:15 pm
    What codec did you transcode to? The most foolproof is to transcode to a DNxHD codec and also transcode audio. Basically nothing in your sequence should be referencing an AMA sourced clip.
    Move the sequence to its own bin, transcode, then look at the Video Format column to ensure everything is now DNxHD.
    Michael
    Michael Phillips
