Activity › Forums › Avid Media Composer › AMA playback
AMA playback
Posted by Peter Giffen on February 20, 2011 at 12:54 pmI am trying to edit with AMA media from a canon 7D
Everything imports great but it just won’t playback smoothly.I import the same footage into FCP and it plays 95% smoothly with a small hiccup here and there.
Why will my Avid not play it when the Final Cut will, I am on version 5 with a Nitris DX.
Michael Kammes replied 15 years, 7 months ago 3 Members · 4 Replies -
Shane Ross
February 20, 2011 at 1:23 pmHow fast is the computer? How old? You need fast processors to play back the H.264 files the Canon cameras shoot. And really, no matter what, you should transcode that format to an editing format. ON the FCP side, ProRes. On Avid MC, DNxHD.
Shane
Read my blog, Little Frog in High Def -
Peter Giffen
February 21, 2011 at 7:50 pmTHe fcp and avid I am using are on the same machine. 2 year old mac tower dual core running snow lepard. Could it be a ram issue? THe fcp choked 2 twice in 6 hrs but the avid couldn’t play 5 seconds before stopping.
Shane Ross
February 21, 2011 at 9:22 pmWell, my 2008 Octo 3.0 GHz mac chokes on H.264 from my Canon DSLR in FCP or Avid via AMA. It isn’t designed to be edited. Access it, and transcode it. Don’t believe marketting hype.
Shane
Michael Kammes
February 22, 2011 at 7:34 amAcross the board, Avid does not guarantee playback via AMA.
And I quote:
“Please note that AMA is a processor intensive application, and older platforms may not offer optimum performance.”
and
“Playback performance of QuickTime AMA files might vary depending on a number of factors including storage type, CPU, and codec complexity.”
That’s the trade off for instant access to media: no guarantees of 100% playback. If you want 100% RT playback, transcode to an Avid DNxHD – it will work better for you later on if you do any kind of color or effects work, anyway.
I’ve even seen hiccups on the new 12 core Westmeres.
That being said, Avid 5.5 (shipping in about 3 weeks) is supposed to have improved playback for Long GOP codecs, but I cannot personally speak to it.
I recommend ensuring that all other bottlenecks are remedied: playback as little number of tracks if possible, go into yellow/green or yellow/yellow mode, other apps are shut down, you have enough RAM and a decent video card, and ensure your system meets Avid qualified spec list (gfx card, RAM, OS, etc): https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=362919&Hilite=apple+macintosh+specifications
Good Luck (and have some patience while Post catches up with those pesky camera peeps!)
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.com
.: twitter: @michaelkammes
.: facebook: /mkammesHear me pontificate: Speaking Schedule .
