Activity Forums Avid Media Composer AMA-Linking C300 footage in Avid MC 8.3 without INDEX files?
  • AMA-Linking C300 footage in Avid MC 8.3 without INDEX files?
    Posted by John Northrup on February 26, 2015 at 6:31 pm
    Hello,
    I was given a few drives full of C300 media that had been heavily rearranged. I rebuilt the folder structure (Card > CONTENTS > CLIPS001) and added the INDEX files wherever they existed (about 20% of the footage). I successfully AMA-linked / consolidated any footage that still had an INDEX file, but I cannot link to the rest of the media from Avid.
    The only way I can get it into the project is by a direct import, which is time-consuming and ties up Avid. Furthermore, without the INDEX file, the clips come in segments (i.e. they’re not sewn back together on import).
    Does anyone know a way around this problem? Or is there no hope once the INDEX files have been deleted?
    Thank you.
    John
    Michael Phillips replied 11 years, 6 months ago 3 Members · 3 Replies
  • Mark Spano
    February 26, 2015 at 7:54 pm
    You should still be able to AMA link the individual MXFs, using the MXF (generic) AMA plugin. However, I know no solution to having them come in as spanned clips again instead of individually, which is a drag.
  • John Northrup
    February 26, 2015 at 10:08 pm
    Thanks, I am able to AMA link them now. I had “autodetect AMA plug-in” selected when it wasn’t working. Still not spanned, but at least able to consolidate in background.
  • Michael Phillips
    February 27, 2015 at 2:54 pm
    Autodetect does not work well at all with any format expecting to use a card structure of folder hierarchy. Always select actual plug-in to avoid madness.
    Michael
