Activity › Forums › Avid Media Composer › AMA Linked Sequence transcode to DNxHD 185x Issues
  • AMA Linked Sequence transcode to DNxHD 185x Issues
    Posted by Edward Gibbs on July 12, 2016 at 1:55 pm
    Hi, I’m having issues transcoding an AMA linked sequence, what seems to happen is a section of V1 is missed and then the whole of V1 is then shifted / offset by the amount missed from then onwards. V2 is complexly unaffected. I’ve tried lifting out a clip that I though may be an issue, but I still get the problem. Has anyone had this before?
    To give a quick rundown of the workflow
    I’m on Avid Media Composer 8.4.5
    the editor has finished a sequence cut at proxy, I’ve relinked the sequence back to the 4k XAVC-I source files and am now attempting to transcode the sequence to DNxHD 185x to deliver to a VFX company to start their work. As a side note, the rushes were acquired at 4k for resizes, not for finishing resolution, the finishing is still at HD.
    Thanks in advance!
    Ed
    Edward Gibbs replied 10 years, 2 months ago 2 Members · 2 Replies
  • John Pale
    July 12, 2016 at 7:38 pm
    We’re the proxies a different frame rate than the originals?
  • Edward Gibbs
    July 13, 2016 at 1:57 pm
    Yep, all the same frame rate
    I discovered that it was being caused by a resize effect on the clip, stripping it off fixed the issue. Clueless as to why though, some kind of bug?
