Activity › Forums › Avid Media Composer › AMA Link
AMA Link
Posted by John Hill on February 1, 2017 at 3:00 amWhen I want to import media – a photo – on my mac I can see under Media heading my Music, Photos, and Movies and I can click on each of those to see their files. But when I go to the Source Browser to ama link to a photo I can’t find all of my Photos as I did when importing. I can only see Photos Library with all of its many folders, originals, Plugins, Data, etc.
Is there an easy way to find photos by ama linking in avid mc now?
JohnJohn Hill replied 9 years, 7 months ago 4 Members · 12 Replies -
Shane Ross
February 1, 2017 at 6:28 am[John Hill] “on my mac I can see under Media heading my Music, Photos, and Movies and I can click on each of those to see their files.”
Media heading? Sorry, I’m not sure what you are saying. Where exactly are you looking? What is the file path of the photo? For example, mine are stored HARD DRIVE>USERS>ME>PICTURES>photo I am looking for. Where are yours located?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
John Hill
February 1, 2017 at 11:54 amThanks, Shane, I thought that might be my issue. I keep my photos on my raid drive, Qx2. They are there in my Photos Library. They are not on my Mac hard drive. How should I correct this? Does that mean I won’t be able to see them as I can when I IMPORT a file? Maybe I have to put a folder on my desktop that contains the photos I want to use?
Michael Phillips
February 1, 2017 at 6:03 pmAgreed – the new source browser allows either LINK or IMPORT so there is no reason it cannot navigate and behave like another folder containing media assets. There is something else afoot.
Michael
Shane Ross
February 1, 2017 at 7:13 pmIf you are looking at the Photos WITH PHOTOS open, that is not something Avid can do. You need to know the physical location on the drive.
Shane
Little Frog Post
John Hill
February 1, 2017 at 7:26 pmI can see the Photos Library on my external drive, but to actually see thumbnails of the photos requires so much work that it’s clear that I’m doing something wrong. When I open Photos Library I see 13 folders like Masters, Modified, Originals, etc. If I click on a folder I see many more folders based on Years. Within those folders are many numbered folders, which is not very helpful. I must be doing something very basically wrong. Thanks for your help.
Michael Phillips
February 1, 2017 at 11:21 pmSo if you drill down to the very last folder that contains actual images, you see nothing? One thing to check is to ensure than none of the folder names anywhere along the line as illegal characters like / * , etc.
Michael
John Hill
February 2, 2017 at 2:48 amThanks for your help, Michael…when I drill down and after opening numerous numbered folders, there is always an image when I open a folder. But I have no clue as to what that image will be. Not a sane way to work. What I want is a way to see all the photos in one window. Here is a pix of what I’m talking about when I try to link. And another after choosing to import media instead of using the source browser – which shows Photos under the Media Heading . In that instance when I click on Photos all my photos appear in one window.
John Pale
February 2, 2017 at 1:53 pmAh. You mean Apple Photos.
Yes, Apple Photos uses its own deeply nested folder organization scheme tied to a database that only it understands. Avid doesn’t natively understand it, at least as far as AMA Link is concerned, so you have to drill through many numbered folders to find what you want. Would be cool if Avid and Apple could work this out, but I wouldn’t hold my breath on it.
From what I understand, you are not obligated to use the Photos Library and Apple Photos can simply link to folders of Photos that you set up (with logical names and organization). You lose much of the iCloud functionality doing it that way, though.
If you want deep integration with Apple Photos, I’m thinking FCPX might be a better fit for you.
John Hill
February 2, 2017 at 2:48 pmThanks John, I should have been clearer…I assumed nearly everyone with a mac used Apple Photos but now I’m thinking that everyone that uses a mac and cuts with Avid uses another app to store their photos.
Thanks again. -
John Pale
February 2, 2017 at 6:54 pmI know its possible in Preferences for Apple Photos to turn off the behavior where it ingests the photos into your library. You can select to leave them in folders of your own creation. I dont think they will sync across devices or be backed up in iCloud if you do it that way. If you are fine with that, it should make things easier as far as Avid is concerned.
I’m a Mac (and Apple Photos) user. I don’t think any NLE except FCPX really has the capability to drill into the Apple Photos Library. I don’t think Apple has opened up the Photos library database to third parties, but I could be wrong about that. Maybe its just not a priority for them.
