AMA Export doesn’t work!
hey folks,
i really need your help on this one. i am trying to export an AMA Sequence with subxlips in it (AMA files have already been successfully relinked). however when i try to export the sequence as “same as source” i get the folliwing error message.
the format of my project is right still it appears.
my offline material (source material) is prosres Hq
online material is dnxhd 185xi want to get a pro res hq mov (without a gamma shift). do you have any suggestions?
thanks a lot in advance!
