Activity Forums Avid Media Composer AMA and Duplicate clips
  • AMA and Duplicate clips
    Posted by Raivan Hall on September 14, 2012 at 8:42 pm
    Hi Everyone-
    FYI- I’m using Avid Media Composer v.6.0.1.1. The original media I’m editing with is Pro Res, which I bring into Avid via AMA and transcode to a 14:1 SD resolution. Once my edit is finished I relink to the original AMA clips and everything is lovely. HOWEVER, if I have two or more clips of the exact same length they’ll show up in my source/record monitor as the exact same footage (like a duplicate clip) even though they’re actually different pieces of footage. I’ve found that for clips that have a unique total run time- there is no issue. It’s ONLY the clips that have identical run time lengths (lets say 20 seconds) that will show up in my source/record monitor as the same clip. When I mount my original media drive and relink the the clips that have the same TRT- its only then that those clips will display in the source/record monitor as the unique pieces of footage they actually are. What’s going on here? Has anyone come across this issue? FYI- I am assigning a tape name to these clips to help Avid locate them. Any and all insight is greatly appreciated!
    Raivan Hall replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
