Activity Forums Apple Final Cut Pro Legacy Am I not capturing my footage properly?
  • Am I not capturing my footage properly?
    Posted by Rishi Kumar on June 22, 2009 at 6:38 am
    Hi everyone, I have had my Sony HVR V1U for few months now, and i was wondering if I was capturing footage correctly.
    Currently I only use normal MiniDV tapes shooting on 24P mode, so therefore in Final Cut Pro I go easy set up and under Use: i have DV-NTSC selected
    Then I just capture ‘normally’ from there, however whenever I drag my captured footage into my sequence, it always asks me if I want sequence setting to match the clip setting..I automatically hit yes, so from there my resolution is 720X480….
    am I doing anything wrong here/
    thanks for the help guys
    Walter Biscardi replied 17 years, 3 months ago 3 Members · 2 Replies
  • Captain Mench
    June 22, 2009 at 10:18 am
    What are the settings on the sequence? Those must match the easy setup of the capture. Maybe you’re trying to cram 29.97 into a 23.98 sequence??
    Mike
  • Walter Biscardi
    June 22, 2009 at 11:03 am
    [Rishi Kumar] “I automatically hit yes, so from there my resolution is 720X480…. “
    720×480 is the correct frame size for DV-NTSC if that’s your question.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
