Activity Forums Compression Techniques Am I missing something BASIC here ??
  • Am I missing something BASIC here ??
    Posted by Michael Alley on March 27, 2008 at 11:55 pm
    I mainly shoot weddings which pan out in their final form at around 1hr after editing. I need to put them on DVD. I export from CS3 as Microsoft uncompressed avi and follow Aharon’s advice in his DVD; but 9 times out of 10 I get an error and Squeeze 4.5 produces nothing other than the error message which is unhelpful. Not really as easy as 1-2-3! I’m reluctant to buy Procoder ( which many here seem to recommend) having just shelled out for Squeeze.
    I have upgraded the drivers and turned Matrox WYSIWYG off. Is there something else I should be checking on please?
    Daniel Low replied 18 years, 5 months ago 3 Members · 6 Replies
  • Daniel Low
    March 28, 2008 at 11:27 am
    What does the error message say?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Ben Waggoner
    March 28, 2008 at 12:33 pm
    If you’re already in CS3, you might as well just encode in-suite. Both Premiere/Encore and Squeeze use the same Main Concept MPEG-2 encoder, so you shouldn’t get any quality difference at best.
    Ben Waggoner
    Principal Video Strategist, Silverlight
    Microsoft Corporation
    Compression Blog: on10.net/blogs/benwagg/
    Compression Classes at Stanford and PSU: on10.net/blogs/benwagg/21622/
  • Michael Alley
    March 28, 2008 at 10:09 pm
    Thanks Daniel and Ben. . . .
    The message, which pops up almost immediately on pressing ‘squeeze’ simply says ‘there was an error compressing the film’ or words to that effect – doesn’t help much!
    I should also have said that I need to compress showreels for use on my web site so I really would like to solve this.
    Any more ideas, please?
  • Daniel Low
    March 31, 2008 at 3:01 pm
    Have you tried using another codec for export like Quicktime Uncompressed or Quicktime MJPEG or PJPEG?
    If nothing works then you really should get in touch with Sorenson for support.
  • Michael Alley
    April 6, 2008 at 8:00 pm
    Thanks, Daniel,
    I haven’t tried Quicktime uncompressed – maybe I will . . . but the point is it should work with uncompressed avi and doesn’t.
    Think I’ll take your advice and try Sorenson again – I must have something incompatibe which is spooking it, I think.
  • Daniel Low
    April 6, 2008 at 8:11 pm
    In my humble opinion, avi is an unreliable file format. Quicktime however is not. If the Quicktime method works, why waste time trying to figure out the avi route?
