Activity Forums Apple Final Cut Pro Legacy Am I going from HDV to SD DVD properly?
  • Am I going from HDV to SD DVD properly?
    Posted by Daniel Wilson on August 1, 2008 at 8:47 am
    I’ve been using a workflow which is roughly based upon Nate Weavers guide lines about the HDV – SD workflow but recently I’m wondering if I’m getting it wrong. Mostly, I’m concerned with what’s happening regarding the conversion from progressive to interlace. Here’s what I’m doing:
    Shoot HDV 720p50 on HD-200 / DR-HD100
    Bring the files into FCP and use the Media Manager to convert it into ProRes422
    Work in a ProRes422 50p sequence
    Export to SD Mpeg2 from compressor, trying progressive, and both upper and lower dominance options to see what works best.
    When I choose upper for example, I’m assuming that compressor is creating an upper 1/50th of a second field from the original 50p frame, then creating a lower 1/50th of a second field from the next original 50p frame. I’m also assuming that if the original clip was 25p, each pair of fields would be taken from the same frame instead.
    Is this correct? if so, should I be using upper or lower for SD PAL DVD?
    If I choose progressive in compressor, will it be creating a 50p or 25p Mpeg2?
    Can SD DVD players even output an SD 50p signal?
    Does this workflow seem solid enough or am I doing something unnecessarily destructive along the way?
    Dan
    Rafael Amador replied 18 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    August 1, 2008 at 10:13 am
    Hi Dan,
    [Daniel Wilson] “When I choose upper for example, I’m assuming that compressor is creating an upper 1/50th of a second field from the original 50p frame, then creating a lower 1/50th of a second field from the next original 50p frame. I’m also assuming that if the original clip was 25p, each pair of fields would be taken from the same frame instead. “
    It should be like that. I haven’t found not info on this topic in the Compressor manual, but this article of M. Solorio points in that direction:
    https://library.creativecow.net/articles/solorio_marco/interlacing_progressive_footage.php
    [Daniel Wilson] ” if so, should I be using upper or lower for SD PAL DVD?”
    If you choose Lower your MPG2 will be Lower, if you choose Upper, the MPG2 will be Upper.
    This changes nothing.
    If you choose Progresive you will get a 25p. MPG2 High Profile supports 50p, but DVDs use MPG2 Main Profile, supporting only 50i/25p.
    I think that your workflow is correct. just make some tests with a few seconds long clip. Pick some images with a lot of movement. There is where you can see if the interlacing have been prperly managed.
    rafael
    http://www.nagavideo.com
