  • Posted by John Fishback on April 13, 2006 at 9:09 pm
    I thought I had fixed this problem. Recently FCP has started exporting ref files with random field order. Some ref files are upper and others are lower and a couple are progressive. This is from the same sequence whose setting for field order is lower. I determined the field order by looking in the inspector in Compressor after importing the ref files. (I export video only, use DVDSP markers and separately export aiffs).
    What I’ve tried to fix this: Trashed FCP, DVDSP and Compressor prefs and repaired permissions. I made a new sequence in the existing project and copied the old sequence into it. I made a new project, opened a seq and copied the old into it. In all cases I exported the same file. In all cases the file comes out with upper order when the seq settings are lower. I tried making a mv2 in Compressor, setting the field order to upper and burning it to see if the field order really was upper and it was. (It looked fine on the DVD).
    I’m stumped. Any ideas?
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
    John Fishback replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
