Activity Forums Apple Final Cut Pro Legacy Am going to FCP… quick question?
  • Am going to FCP… quick question?
    Posted by Aj Reuter on February 4, 2011 at 7:44 pm
    Im a highschool student in TV2 college course. I am going to start doing my own thing, and making videos for my portfolio. I dislike using premiere, i want to go back to using fcp like i did in middleschool.
    I cant afford anything too fancy…
    I was going to buy
    Imac
    3.06 ghz core i3 (or 2duo)
    4gig ddr3 ram
    750gb HDD
    But i am leaning towards
    Macbook
    2.24ghz core 2 duo
    4 gig ddr3 ram
    500 gb hdd.
    For videos 5 mins or under, in 1080… I know the Imac will do it (friend has the same one, does all the stuff no problem…) But i was curious if it would be okay on the macbook pro.
    I would love something portable, but the speed is a big downgrade. They are both same price… Input?
    Dan Monro replied 15 years, 7 months ago 3 Members · 3 Replies
  • Rafael Amador
    February 4, 2011 at 7:57 pm
    The only MacBook you can compare with an iMac now, is the 17″ and that is in terms of connectivity (SxS slot), not about power.
    I wouldn’t buy that MBP. Whenever you’ll need to render, the iMac will do it in half the time.
    If you can afford the i5/i7
    rafael
    http://www.nagavideo.com
  • Aj Reuter
    February 4, 2011 at 9:09 pm
    Well, i cant. I can only get the i3 imac
    Basically. its between those two.
  • Dan Monro
    February 4, 2011 at 10:31 pm
    I edit on my MBP. HD. Its not as fast as my desktop system, but I haven’t had any real issues. I run FCS3 and Adobe CS4 on it. 2.53ghz with 4g of ram. I would think it should suit you, especially if you want portability. I do run all of my media on an external drive via firewire 800. Again, not optimal, but it works for me.
    Good luck,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
