Activity Forums Adobe After Effects Always Preview This View
  • Always Preview This View
    Posted by Neil Robinson on June 1, 2011 at 10:52 am
    Hello, I’m using a 3 screen setup with AFX and use a AJA video card with a grade one monitor to preview the output. I recently discovered the Always Preview This View button, which I first thought great I can preview the main composition while working in a seperate comp ie a comp with shape layers fine tune it, change colours etc but see how that looks within in the main comp (Alyways Preview This View). It just doesn’t resond live if you know what I mean I have to click the main comp for it to refresh which sort of defeats the reason for using it. Does anyone know if there is a setting somewhere to give live feedback on Always Preview This View? of course I could just build the shape layers and fine tune it in the main comp until I’m happy with it then Pre-compose it.
    Neil R
    Neil Robinson replied 15 years, 3 months ago 2 Members · 2 Replies
  • Steve Renard
    June 1, 2011 at 1:20 pm
    I’m not sure if you will be able to get a live update/preview on an output monitor, but you could open up another comp tab for your main comp, lock it, and then edit your sub-comp in another comp tab.
  • Neil Robinson
    June 3, 2011 at 9:46 am
    Thanks Steve, I’ve tried that and works fine. It doesn’t respond live, but when you click off it does refresh. Cheers Neil
    Neil R
