Activity Forums Adobe Premiere Pro alt+shift for replacing footage at same time not working
  • alt+shift for replacing footage at same time not working
    Posted by David Cabestany on August 27, 2019 at 1:57 pm
    I’m replacing low res footage with high res, I’m holding alt+shift while dropping the new clip on top of the low res and it’s not keeping the same in points I initially set.
    This worked fine until last night, and I did not change any shortcuts or anything else.
    Your help is appreciated.
    Danial Monson-bergum replied 4 years, 6 months ago 4 Members · 4 Replies
  • Todd Perchert
    August 27, 2019 at 2:28 pm
    Never used Alt-Shift-Drag, but use Alt-drag to replace clips all the time. It keeps the set in points of the clip I am dragging onto the timeline. If that’s what you’re looking for. I just tried Alt-Shift-drag and it seems to go to beginning of clip.
    TC
  • David Cabestany
    August 27, 2019 at 3:53 pm
    Really? Maybe I had it wrong this whole time. I use alt-drag to replace clips and have them keep the scale to fit feature activated, but I always thought that to also maintain the in point the shift keed was required.
    I’ll check as soon as I have a minute, I’m on a deadline with my current project.
    Thanks for your help.
    D.
  • Ann Bens
    August 27, 2019 at 7:27 pm
    Alt+drag will do what you want.
    Adobe Certified Expert Premiere Pro CS2/CS6/CC
    Adobe Community Professional
  • Danial Monson-bergum
    February 23, 2022 at 6:11 pm
    When replacing a clip on the timeline with another clip from the Project panel or the Source panel, I only ever knew of Alt+drag. I love being shown this new shortcut!
    Alt+drag replaces the clip according to the replacement clip’s in-point. Alt+Shift+drag seems to replace the clip according to the current clip’s in-point.
    This only seems to work on a clip-by-clip basis, however. When I select multiple clips on the timeline and perform Alt+Shift+drag with a replacement clip, Premiere seems to produce through-edits of the replacement clip at every subsequent edit.
