Activity › Forums › Lighting Design › Altman Q360 spotlight not sharp – what gives?
Posted by Shawn Miller on April 3, 2009 at 5:56 pmHi all,
I just recieved an Altman 360Q spotlight and I can’t seem to get it to focus properly. The best I can seem to get is a somewhat soft pattern on a wall 23 feet away using a steel gobo. What puzzles me is that I can get it to focus if I move the lense half an inch further (forward) than it was designed to go. Am I missing something?
Shawn
Shawn Miller replied 17 years, 5 months ago 3 Members · 5 Replies -
Dennis Size
April 4, 2009 at 2:16 amI’m sorry you ended up with a 360Q (How’s that “green” beam of light working for you?)
You’re using the wrong lens for the distance you’re trying to project your gobo at. You will never get a sharp image with an inappropriate focal length lens.
I would guess you have a 4 1/2″ x 6 1/2″ fixture (maybe even a 6″ x 9″).
For the distance you’re trying to light you need a 6″ x 12″ lens tube.Out of curiousity, what is the beam spread diameter on the surface at the distance you’re lighting?
DS
Shawn Miller
April 8, 2009 at 11:12 pmHi Dennis,
Sorry for the delayed response, it’s been a busy week.
“How’s that “green” beam of light working for you?”
I haven’t noticed a shift in color so far… does this model have issues with color?
“I would guess you have a 4 1/2″ x 6 1/2″ fixture (maybe even a 6″ x 9″).”
I have a 6×16 lense tube.
“what is the beam spread diameter on the surface at the distance you’re lighting?”
About six feet.
Shawn
John Sharaf
April 8, 2009 at 11:28 pmThe lenses in these type of pattern lights are not the highest quality, a;though Source Four has recently added a line of “enhanced definition” lenses as higher prices to solve the issue you describe. Of course you must carefully calculate the trhe distance of the throw, the desired size of the light pattern and then deduce the angle of the lens required.
JS
Dennis Size
April 9, 2009 at 4:30 amHistorically the Altman 360Q — one of the more “economical” lekos on the market — has always emitted a beam of light that was slightly “greenish” due to the glass used.
As I said before, you’re using the wrong lens. I assumed for such a short distance you erred on the wide angle side. The 6″ x 16″ lens is made for throw distances of about 40′-0″ (also useful at 30 feet if you don’t mind the small beam spread), and will never achieve a sharp focus at 20 feet.
As I said, for your distance you need a 6″ x 12″ lens tube (or even a 6″ x 9″ if you need a bigger beam spread).
Your best bet if you’re never projecting at the same distance is to purchase a zoom leko (ellipsoidal).
ETC makes an excellent 25 degree to 50 degree zoom ellipsoidal which would be ideal for your range. If intensity is not as important, but size and weight is, the Source 4 Junior zoom would be your “best friend”.DS
