Activity Forums Avid Media Composer Alt+Left-Click Quick selection in Bin question.
  • Alt+Left-Click Quick selection in Bin question.
    Posted by John Keating on March 5, 2016 at 5:41 pm
    Im referring to the feature in the bin where you can click an empty field in one of your bin columns with Alt+Left-Click and it will show you everything you have named in that field previously.
    I love this feature but it ends up showing me about 15 things at once as I progress. Is the any way to remove select things to remove from the window to make this more useful for me?
    John
    Michael Phillips replied 10 years, 6 months ago 2 Members · 1 Reply
  • Michael Phillips
    March 5, 2016 at 7:46 pm
    There’s no controlling that pop-up menu. There have also been requests in the past about populating those menus ahead of time so that loggers would would be consistent in spelling and such for searches downstream. There used to be a function where you could ALT tab past a column and it would inherit the value from the clip below it. That doesn’t seem to work any more.
    Michael
