Alternative to Track Matte (Alpha).
Hello, I hope everyone’s doing well. I’m currently dealing with a situation that I haven’t solved yet and I’m kindly asking for any input or suggestions you might have. I’m working on a new project, which is finally done, and the client wants me to export tiny clips to JSON to use on his website. Therefore, I’ve installed Bodymovin, which works with Lottie, a Javascript library that loads that JSON file. And everything turned out fine until I went by the last bit which has an Alpha Matte applied and it doesn’t work, because Lottie doesn’t support that feature yet. It exports the actual shape layers inside that pre-comp (with lots of animated shapes). This pre-comp has a Track Matte to reveal the pre-comp above. So, I was thinking if there’s an alternative for the Track Matte feature that has the same or, at least, a similar outcome. Thank you so much and I really appreciate any feedback regarding this issue. Have a nice week, everyone!
